I am trading in my 2008 C14 for a new 2011 C14. Being that I am 6'2", I want to install Heli risers and footpeg lowering kit for more room. Anyone with feedback?
we have the same problem, when things don't fit us, we must make adjustments. I'm 6'6'' and the motorcycle larrys footpeg lowers are perfect. I rode it for 1 hour the other day, never took feet off pegs. my ability to take long rides on this bike is governed by the seat. the stock seat hearts my butt. I have a corbin seat on order. had them build the seat 2'' higher for rider, since their off the shelf seat is cut 1'' lower than stock. with the seat and pegs, now i've add almost 3'' more leg room. since i have long arms, the bars are okay for now. just going to add the foam grips. hope this helps big guy.
