I've run into a snag on a valve adustment and looking for any suggestions. 2008 Concours 14 - all 8 exhaust valves wree out of spec, and 6 of 8 intake valves were at their maximum tightness. I installed new shims (one bucket at a time), put the cams and covers back on (per the shop manual and Fred's video's) , and check the valves again - found to be perfect. Put it back together - will turn over but will not start. I've done the obvious - took the valve cover off again and checked the timing marks, they look perfect. I've check all the electrical for crimped connections, installed new plugs, and made doubly sure that the stick coils are fully seated. I also turned the engine over with the #1 stick coil out and with a plug grounded to the engine - and I don't see any spark. I get no codes. Any suggestions?
