I see you only have 5 posts. Setting may have been imported from the old forum that requires a user to have a minimum number of posts before being able to post in classifieds to limit spam classifieds.
@badfahts, I can't see any reason why you can't post in the classified section.
When you are in the classified sections is there a post thread button in the top right corner? forum
or at the bottom of an existing thread a box to enter a reply?
If none of these exist I suggest logging out of the forum and the member site. Clear your browser cache and log back in to the forum.
