So it is looking more and more like my job situation may be not so good right around the time I will be needing the 14k mile service (Will need it by Nov/Dec but will do in spring) so I likely will not be able to pay the stealer to do it. Inotherwords, I will probably have to do it myself...
Now I've done some fairly grizzly work on cars.. (Timing belts, Cyl head swaps etc) and I've done timing belts and a cyl head swap on a 2v Ducati, but nothing like this.
I have Fred's videos, and I've watched them several times now, it doesn't LOOK too difficult, just tedious.
So my questions are:
1) How easy is it to get the timing wrong and how far off does the engine need to be to bang a valve? (I've seen some cars where 1 tooth allegedly can bend a valve)
2) How much would a decent precision Micrometer cost me
3) Do most dealers have to order shims or do they have them in stock usually? Also how expensive are they?
4) How easy is it to strip a bolt on the cam covers (After all, most of the rest of the fasteners are made of Fine Chocolate) and if that happens how bad is it?
5) After re-installing the Cams, and I turn the motor over by hand to feel if anything is out of whack, if I feel something start to touch, is it ok to turn the motor the other way to line it up and re-adjust the timing, or do I need to pull the cams where they are and THEN re-turn the motor?? (Also, I assume if I turn by hand and feel no interference I won't bang a valve on start up if it's a tiny bit off)
Lastly, with regards to the Cam Chain tensioner, It looks pretty straightforward, but once I retract it to re-install, how can I tell if it went back in properly and didn't push out too far when tightening it down (I remember reading someone who had the tensioner OVER tight and the chain snapped grenading the motor)
I am pretty confident I can do it, but just want to make sure I cover ALL the bases
Thanks in advance
Thanks in advance
