anthony - Sacramento said:are you talking about the rear shock ? if so im 240lbs and i have it set at full stiff , the forks are set at 10 clicks down from all the way out , and my fork springs are all the way in , rides great , takes the turns a lot better no floating .
my settings stay the same 1 or 2 upZG said:anthony - Sacramento said:are you talking about the rear shock ? if so im 240lbs and i have it set at full stiff , the forks are set at 10 clicks down from all the way out , and my fork springs are all the way in , rides great , takes the turns a lot better no floating .
He's asking about with passenger, pillion = passenger...
anthony - Sacramento said:my settings stay the same 1 or 2 upZG said:anthony - Sacramento said:are you talking about the rear shock ? if so im 240lbs and i have it set at full stiff , the forks are set at 10 clicks down from all the way out , and my fork springs are all the way in , rides great , takes the turns a lot better no floating .
being smart dont matter in my case ,, my settings are as stiff as it gets , cant go any farther , so 1 or 2 up dont matter for me .. ride smoothZG said:anthony - Sacramento said:my settings stay the same 1 or 2 upZG said:anthony - Sacramento said:are you talking about the rear shock ? if so im 240lbs and i have it set at full stiff , the forks are set at 10 clicks down from all the way out , and my fork springs are all the way in , rides great , takes the turns a lot better no floating .
That's not smart, unless Kirby is your passenger...
anthony - Sacramento said:being smart dont matter in my case ,, my settings are as stiff as it gets , cant go any farther , so 1 or 2 up dont matter for me .. ride smoothZG said:anthony - Sacramento said:my settings stay the same 1 or 2 upZG said:anthony - Sacramento said:are you talking about the rear shock ? if so im 240lbs and i have it set at full stiff , the forks are set at 10 clicks down from all the way out , and my fork springs are all the way in , rides great , takes the turns a lot better no floating .
