According to my MSF BRC course, low tire pressure is the number one cause of tire failure. This is a good time to bring up checking tire pressure with temp changes because we're starting to get big swings in the SE, with warm to hot afternoons and cool mornings. With swings like that, got to keep a close eye on that pressure. I don't really check my tire pressure on a regular schedule. I check it when there's a temp change and I check it once every week to 2 weeks. I've never seen a visible sign of my tires being low so that's not an issue. I do perform a visual inspection before I ride and I'll give the tires a squeeze. If handling feels a little sloshy in the rear, I'll stop and check my tire pressure, though that hasn't happened since I replaced my rear tire.
I check every ride because you just can not tell from look or feel. I had a tire with 16 lb in it and you could not tell by any method it was really that low. If you leave the safety and comfort of your home with a nail in your tire then it can cause much more pain and suffering later down the road. ---------------------------------- I will answer any question. It is up to you to figure out if I should have.
smithr, no offense but how often do you ride? Myself I picked every now and again. I wish I was able to select once a week. That would be my best selection. Somehow I just dont see myself taking the time to check this every morning / evening before I leave for work and/or home. 2003 Concours COG #6953 http://mysite.verizon.net/slybones/Concours/connieMain.htm
I have to agree with Sly... I ride every day so I don't have the time when I ride. I too picked "every now and then" because I do check every two weeks (+/-) when I do a check on the bike. Yuma, Summer in Yuma is not hell, but hell is a local call 2006 Connie http://community.webshots.com/user/Lateck?vhost=community
Weekly for me, but when I'm on a long ride I check it every morning. Nothing is more important to ride quality, traction and safety! Steve K. '02 Concours COG# 6550 AMA# 965469 'No matter where you go, there you are...'
I usually check once per week unless on a trip, then I try to check every day. Saturday is the day. Check the bikes, the wife's car and the truck. Eddie 2005 Concours 1969 Triumph Bonneville AMA# 686667 COG# 7073 CDA# 0136 http://picasaweb.google.com/Eddie753
There is no real need to check your outside tire pressures. Barring any significant weather issues my tire pressure always reads 14.7 pounds per square inch at sea level. However the inside pressure I do check at least once a week. :eg: Another benefit to doing this is you get your face close to the tires therefore it is easier to inspect them and detect any issues. ;p AKA "2linby" That's 2-lin-by folks! Northwest Area Director COG #5539 AMA #927779 IBA #15034 TEAM OREGON MC Instructor http://community.webshots.com/user/2linby http://tinyurl.com/njas8 (IBA BunBurner Gold Trip) http://tinyurl.com/lwelx (Alaska trip)
I check 1 week after a tire change and then about 2 weeks after that to see how much, if any, pressure drop has occurred. Then I usually check about once a month after that. Of course, I always check the pressure before a long ride too. YMMV Brock T. Delp '99 Concours "Gypsy" COG #3903/A IBA #15224
So Far the Electronic Tire pressure sensor on the C-14 works good , and makes checking easy at the start of my ride . I compare the reading with a Tire gauge about every two weeks to be on the safe side .
I stopped riding to work so yes I only ride about once a week when at home. Usually the bike has sat a few days or I have put on lots of miles last time I rode it so it needs to be checked. Either way I have helped a couple people plug tires just miles from home base because they did not check them before leaving. ---------------------------------- I will answer any question. It is up to you to figure out if I should have.
About every 2 wks but always before a long ride. I bought an 10 gallon air compressor for the garage for mainly checking tires. So convienent in the garage vs. a gas station. Plus it's great for drying the bike and removing standing water after a bike wash! ~Moto Madness 2009 Kawasaki Concours 14; Black, ABS 2008 BMW F800ST Catching a yellow jacket in your shirt @ 70 mph can double your vocabulary
I use a tire knocker every time I leave the house. It's close to the bike and only takes a few seconds to check em. With a little practice you can tell when the tires don't sound and feel right when they're are a little low. Also use a dial guage that I keep on the bike for when I'm away from home.
Before every ride; local or on a trip. Just a habit I picked up long ago. Have taught my wife and son to do the same. Hopefully, both are still complying. Take care and ride safe, Bob Young State of Jefferson COG #5753
I check the tire pressure every time i ride and having a C14 all I have to do is look at the gauges. that is a very useful feature. I find it somewhat annoying trying to pump up the tires. now I use my portable 2 gallon air compressor which works fairly well. I also found that especially my rear tire seems to loose air , between 2 to 4 psi within a week or so. Not maintaining proper pressure also effects the longeivity of the tire and on a C14 that's even more critical. happy if I can between 4 to 5000 miles out of the rear tire. Ted Proud to be American! (since 2005) Lost and found in 1991 2008 C14 "Freebird"
