The Mad Duck
Bicycle
I need to adjust the idle after installing the aftermarket exhaust and PC V. The idle is too low even after warm up.
I was given a tip here to find the idle adjust tube/screw on the back of the front fairing. I also consulted my 2011 Concours 14 ABS Owners Manual. On page 216 in the Maintenance and Adjustment section there is a really poor image of the idle adjustment. It appears there is a rubber tube with a metal adjustment screw at the end. My adjustment screw seems to be missing. Is it possible to adjust with a screwdriver inserted into the rubber tube? OR, do I need to get a screw into the tube? If so, does anyone know what size this idle adjuster screw is? Any help would be much appreciated.
