jfryhayes@aol.com
Training Wheels
Hi. I'm lucky that the only trouble with my conc is is that the clock resets after any significant ride.
First of all the fuse appears good.
The clock DOES work when the ignition is powered off -
EXCEPT , for maybe an hour after a ride.
It is heat related. A short ride or a ride in the 30's won't shut the clock down.
Clock works always with the ignition on.
During service this winter, I traced the power wire from the j box to the clock , fiddling with connectors on the way, with no improvement. (fiddling = cleaning)
I am asking for advice on where to look for this open circuit that occurs only when hot.
Do I need to go through my j-box? I assume the ground is same whatever the power source is and can't remember if I traced that.
Thanks
I would add that this minor issue irritates the heck out of me - especially in the morning as I head off late to work. Or is it late. I don't know!
Thanks
