I have seen on concours.org that a issue of Concouriers had an article on cleaning Connie's carbs. Does anyone here know which issue that would be so I can download to do my 2000's carbs? Thanks.
Concouriers are now back online I don't recall which one it was off the top of my head. Good opportunity to view them all Colin Colin Prior Cogmos Committee Chairman Lake Forest Park WA COG#7767
I'd like that article as well... I don't see it in any of the archived Concouriers listed. Fall 2006 isn't listed either? Help please, tearing into my 1995's carbs for a thorough cleaning this weekend, she won't idle at all.... Thanks
Not sure I can help. I can not post the info as it is copy righted. I am not sure why they have not scanned that issue but I do not think they are working on it this weekend so not help. Here is a link that others said help them but it is not on Concours but is similar inline 4. http://www.thegsresources.com/gs_carbrebuild.htm
Yes - That link that Bob S. provided should be very helpful to Concours owners. The GS Resources - is a very good website dedicated to the line of Suzuki GS motorcycles built from the late 70's to the mid 80's. I understand that carb rebuilding aticle is excellent, and should relate very well to the Connie carbs. Good luck -
