Just purchased a '03 Connie & have been look'n @ possible engine / timing advances . . My question is ~~ Would a 4degree timing advance or exhaust cam sprocket be a better choice for increasing low & mid range TQ & better roll-on performance
Jeff, Don't think I can answer your question but... Wondering if you are interested in attending the May 1st Tech Session in Monson, MA? I know of at least one person who has installed the exhaust cam sprocket mod and could comment on the difference. Details on the Tech Session are on the Calendar. Greg H from Mass, Connie Droppers Anonymous Awards Dude COG# 7010,a Tracey CDA 120 (2.0) 99 Connie "Herrin Christabelle", 05 Ninja 250
Jeff - the difference btween the sprocket and advancing the timing is that the sprocket actually helps trap a stronger cylinder charge by cutting the cam's overlap period, whereas the timing advance increases the timing 4* everywhere, which on the connie isn't a good thing when operated in a torque fashion (low rpm) as detonation can result. I'd also like to mention I'm just about done with my newest jet kit - the "2 minute mod kit" it involves blocking 50% of the intake and rejetting the carbs. the power is immediate and very noticeable. Nothing like you'ld ever expect from just a jet kit. I'm gathering components kits now, so soon, very soon... Steve
Howdy Steve Thanks for the info on the exhaust sprocket . . But now should I purchase the jet kit you are offering with the sprocket or wait and go for the the 2min mod w/jet kit & sprocket seperately ? How would each effect the way my power would track . . I really like "seat of the pants feel" but don't want the back tire breaking lose in i.e. 90 degree departures from an intersection / parking lot etc. ~~ Jeff
Steve, you try the stick coils yet? How do they go with the Jet Kit / Sprocket / 2-min Mod, in YOUR experience. Thanks. 2003 Concours, 58K COG #6953 IBA 28004 http://home.comcast.net/~slybones/Concours/connieMain.htm
Member area calendar has almost all scheduled events for each area "If it hasn't killed me yet, it's runnin out of time" COG # 8062 AMA # 1084053 ROMA or Scarlet harlot acording to my wife
Jeff, Check out the Northeast Calendar on the Home page Here's the event listing: http://www.cog-online.org/clubportal/EventDetail.cfm?clubID=1328&EventID=110447&mo=5&tDate=%7Bd%20%272010%2D05%2D16%27%7D Contact me if you are interested in doing work and/or learning on your bike. Greg H from Mass, Connie Droppers Anonymous Awards Dude COG# 7010,a Tracey CDA 120 (2.0) 99 Connie "Herrin Christabelle", 05 Ninja 250
