Sailor_chic said:
Sailor_chic said:
soonerone said:Sailor_chic said:
One of the best, and I concur...
Yes it is that good !. Why have to mess with hitting buttons. After hitting the buttons the warning DOES go away but you loose the fuel/miles you empty read out. With the "thingie" I don't worry about anything & can "stretch" my tank if need be & not worry about guessing how far I can go till I run out of gas. It now operates how I think Kawasaki should of made it from the beginning "pun not intended"Fais said:soonerone said:Sailor_chic said:
Those of you that have it never tell people about how to deal with the warning light - just how to order the thingie - come on now - I loved learning the trick and it works on all the other warnings that BDF doesn't sell a thingie for. It's the little tricks we share that make this forum great. Sure, order the thing, but until then . . . . . And again, any warning starts flashing, you can hit those buttons. Worst one for me was when I was a few weeks away from home with the 'low tire pressure sensor battery' warning flashing . . . I got really good at hitting those buttons :-[
Zarticus said:Yes it is that good !. Why have to mess with hitting buttons. After hitting the buttons the warning DOES go away but you loose the fuel/miles you empty read out. With the "thingie" I don't worry about anything & can "stretch" my tank if need be & not worry about guessing how far I can go till I run out of gas. It now operates how I think Kawasaki should of made it from the beginning "pun not intended"Fais said:soonerone said:Sailor_chic said:
Okay, We get that you don't like the fuel dongle. To each their own, I'm glad I have it but it's my choice. As far as the '"Secret button combo push" You don't need a decoder ring, It's written clearly in the owners manual. All is good brother :beerchug:Fais said:UNTIL THE NEW GUY GETS ONE THERE IS USEFUL INFO ABOUT THE BUTTONS - AS I MENTIONED IT HELPED ME A LOT WHEN MY TPS SENSORS WERE DYING. IS THERE A THINGIE FOR THAT?
ALSO WORKS FOR LOW BATTERIES AND OTHER WARNINGS
I'LL STAY OUT OF IT - GEEZ - :-[ :truce: :-\
THANKS SAMMIE TIMMONS FOR TEACHING ME HOW TO HIT THE BUTTONS. I HOPE YOU GOT A THINGIE RIGHT AWAY :great:
Daisy said:I thought the little rectangle didn't blink if you use the eliminator? If it still does I'm so having one.
I don't like the way the warnings take over the whole display. .... What I miss is the range function.
Totally miss that 7+ gal tank!One thing I miss from my C10 is that huge fuel tank. Never the first to stop for gas on a ride, always able to go a few more to the next stop. But....though both C10's were great bikes, that's about all I miss!
That is true my friend, that extra 16# (when full) is just adding fuel to the fire...Until it’s overbalanced. Hernia time!
Ha, best not to be topped off in parking lots!
What? I did NOT know that. Is that info in the owners manual? Great info . Thanks.Best farkle?
Really?
I wonder why I don't get it . . . but it's nice that there is at least one accessory for this bike I don't want(!)
FTB - when the fuel warning comes on you can hit the top dash button, then while keeping it pressed, hit the bottom dash button. It gets your dash info back and turns on a warning light until you fuel up. Unless you buy the thing that disables the fuel light this might help you out.
:beerchug:
Yes, this is on the owners manual how to clear warnings messages from the display.What? I did NOT know that. Is that info in the owners manual? Great info . Thanks.
