Need help setting the C-14 Clock
David C-14
Bicycle
I lost my owners manual and I have never have to set the clock before. Can someone tell how is done? Never mind, problem solve. My wife found the owners manual.
LOL :p Bionic Bob COG & AMA member First C14 CDA member #0220 2008 C14 & 2003 Mean Streak
Jose, here's the clock setting process. 1). Hold the upper button on the display in for 2 seconds and the display selection will flash. 2). Push the lower button to select the CLOCK function. 3). In CLOCK mode, push the upper button for 2 seconds to flash the hour & minute displays. 4). Push the lower button to flash only the hour display then push the upper button to change the hour. 5). Push the lower button again to flash only the minute display then push the upper button to change the minutes. 6). Push the lower button and both the hour and minute displays will flash again. 7). Push the upper button and the displays stop flashing and the clock starts working. Kevin COG 145
