JohnC
Street Cruiser
I'm in the process of putting a 86 back together, but taking care to check and clean as much as I can. Since the oil cooler was off, I decided I should clean it as I could easily see a lot of debris that was blocking quite a bit of it. First step, de-greaser, a stiff brush, and the hose. Result, got some out, but still a lot there. Next step, stronger degreaser and a pressure washer. Result, still a lot there. I ended up getting two blowgun darts and using them as pick tools to physically dis-lodge each item, which took some time. Now if you think this was a bit much, take a look at just a very small part of what I got out of it. <a href="http://rides.webshots.com/photo/2508567090053698080qQOaVy"><img src="http://inlinethumb53.webshots.com/46004/2508567090053698080S500x500Q85.jpg" alt="IMG_0483"></a> Now if you don't run a fender extender and you notice the engine running warmer, then I'd strongly suggest that you check the oil cooler. This pic shows what I used as a pick tool to get the stuff out. Yes, one has a slight bend on the end, to pull items out. <a href="http://rides.webshots.com/photo/2289112970053698080dQfmfu"><img src="http://inlinethumb10.webshots.com/44361/2289112970053698080S500x500Q85.jpg" alt="IMG_0486"></a> tcars, John, COG 4157, AMA & ROK Central Jawja AAD
