OK, I am starting this is a list of oil that meets Kawasaki's specifications for the C14. This will be a work in progress. If you would like to add a brand/type of oil to the list, PM an existing moderator with the particulars. But please give all the information as to what directory and what you're looking to do, since there are multiple directories. I do ask that any oil in this list, be available in the correct specifications for the C14 (10W40 and API ratings).
Thanks
Bob
The specifications for the Concours14/GTR 1400 are as follows:
Engine oil type
API SE, SF or SG
API SH, SJ, or SL with JASO MA
Viscosity
SAE 10W40
AMSOIL
10W-40 Advanced Synthetic Motorcycle Oil - http://www.amsoil.com/a/synthetic-motorcycle-oil?zo=1627549
Castrol
Castrol Actevo X-TRA 4T - http://www.castrol.com/castrol/sectiongenericarticle.do?categoryId=9040438&contentId=7040549
Castrol Motorcycle Oil - http://www.castrol.com/castrol/sectiongenericarticle.do?categoryId=82915504&contentId=7040371
Castrol Power RS Racing 4T Full Synthetic Motorcycle Oil - SAE 10W-40 (1 qt.) - http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Power-RS-Racing-4T-Full-Synthetic-Motorcycle-Oil---SAE-10W-40-(1-qt-)-Castrol_99997734-P_N4019C_T%7CGRP2046_____
Castrol 4T Motorcycle Oil - http://www.castrol.com/castrol/sectiongenericarticle.do?categoryId=9040439&contentId=7040925
Kawasaki
Kawasaki Performance Oils (all weights Motorcycle, ATV & Water Craft)
http://www.kawasaki.com/kawasakinew/Accessories2/PCItemsList.aspx?intCatalogID=1&intCatalogType=23&ProductTypeID=150&CategoryId=120
Kawasaki 10W-40 Quart Motorcycle Oil - Item # :K61021-202A - Quart http://www.kawasaki.com/kawasakinew/Accessories2/PCItemDetail.aspx?ItemNumber=K61021202A&Reason=Y&intCatalogID=1&intCatalogType=23&ProductTypeID=150&CategoryId=120
Kawasaki Performance 10W-40 Motorcycle Oil - Item # :K61021-302 - Gallon http://www.kawasaki.com/kawasakinew/Accessories2/PCItemDetail.aspx?ItemNumber=K61021302&Reason=6&intCatalogID=1&intCatalogType=23&ProductTypeID=150&CategoryId=120
Kawasaki Performance 10W-40 Semi-Synthetic Oil - Item # :K61021-206 - Quart http://www.kawasaki.com/kawasakinew/Accessories2/PCItemDetail.aspx?ItemNumber=K61021206&Reason=Y&intCatalogID=1&intCatalogType=23&ProductTypeID=150&CategoryId=120
Kawasaki 10W-40 Quart Semi-Synthetic - Item # :K61021-206A - Quart http://www.kawasaki.com/kawasakinew/Accessories2/PCItemDetail.aspx?ItemNumber=K61021206A&Reason=Y&intCatalogID=1&intCatalogType=23&ProductTypeID=150&CategoryId=120
Kawasaki 10W-40 Quart Synthetic Oil - Item # :K61021-207A - Quart http://www.kawasaki.com/kawasakinew/Accessories2/PCItemDetail.aspx?ItemNumber=K61021207A&Reason=Y&intCatalogID=1&intCatalogType=23&ProductTypeID=150&CategoryId=120
Mobil
Mobil 1 Racing 4T 10W40 - http://www.mobiloil.com/usa-english/motoroil/oils/mobil1_racing_4t_10w-40.aspx
Mobil1 Racing 4T 10W-40 4-Cycle Motorcycle Oil (1 qt.) - (Also known as Mobil 1 MX4T) http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Racing-4T-10W-40-4-Cycle-Motorcycle-Oil-(1-qt-)-Mobil1_8026541-P_N4019C_T%7CGRP2046_____
Mobil 1 MX4T 10W-40 (Racing 4T is still sold in Canada as MX4T, and sold at Walmart)
Motul
Motul 5100 4T 10W40 http://www.motul.com/us/en-US/products/31?f%5Bengine_type%5D=26&f%5Brange%5D=21
Motul 7100 4T full synthetic 10W40 http://www.motul.com/us/en-US/products/39
Rotella - Shell
Rotella -T6 synthetic 5w40 - (Note: Folks like this, but this weight is just outside the parameters, but just barely)
http://www.shell.com/home/content/rotella/products/t6/
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_rotella&174;-t6-5w-40-shell_8120031-p?cm_mmc=ACQ-_-Google-_-National-_-Keywordless--StoreKeywordless--Ad#utm_source=acq&utm_medium=google&utm_campaign=national&utm_content=keywordless--storekeywordless--ad
Royal Purple
Max-Cycle® Motorcycle Engine Oil - http://www.royalpurple.com/product-categories/motorcycle/#!max-cycle-motorcycle-engine-oil
Royal Purple Max Cycle SAE 10W40 full-synthetic - Quart - http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Max-Cycle-SAE-10W40-Royal-Purple_99983726-P_N4019C_T%7CGRP2046_____
Spectro
Platinum SX4 full synthetic - http://www.spectro-oils.com/platinum-sx4/
Spectro 4 - http://www.spectro-oils.com/spectro-4/
TexasTea
http://www.texastealubes.com/
Product Code #773 10W-40 Synthetic Motorcycle Oil - 6/1 quart http://www.sears.com/shc/s/p_10153_12605_SPM6594295402P?prdNo=25
Valvoline
Valvoline Motorcycle Oil 10W-40 Quart - http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Motorcycle-Oil-10W-40-Quart-Valvoline_8080023-P_N3254_T%7CGRP2046_____#fragment-1
Thanks
Bob
Engine oil type
API SE, SF or SG
Viscosity
SAE 10W40
AMSOIL
Castrol
Kawasaki
Mobil
Motul
Rotella - Shell
Royal Purple
Spectro
TexasTea
Valvoline
