Go to Profile > Modify Profile > Personal Messaging and check 'Save a copy of each personal message in my outbox by default.'. then click 'Change Profile'.
Seems to be working. Thanks. I found the save sent item just after posting. I would think that should be on by default, along with email PM's. Some don't check the forum daily and would not know when a message is waiting.
It seems you have to set your profile to receive PMs(poster) by email and also your(respondent) profile has to have send PMs as email set. I am not sure about this but was the way mine was set when I just checked.
