Always has been, since it started, It was done intentionally, so each person that wishes to post a revue, can make a "new" post, and not have people start "fights" over opinions... simply designed as a "revue" only page... I think it works well, and saves the "bad indifference's / fights" very effectively.. and I kind of like it that way..
