Steve C said:In several occasions recently, the rear brake pedal on my '09 ABS has jammed, it won't move at all. Stomping on it several times fixes the problem. The brake recall had previously been done.
Anyone else see anything like this?
Thanks,
Steve
jwh20 said:Steve C said:In several occasions recently, the rear brake pedal on my '09 ABS has jammed, it won't move at all. Stomping on it several times fixes the problem. The brake recall had previously been done.
Thanks,
Steve
You might check that the pivot of the pedal lever is not corroded or otherwise binding. Take it off, clean it, and apply some grease.
TxMotoTech said:ABS module- possible but highly unlikely. Start with the basics and go through a process of elimination from simple to more complex. First thing I would do is make sure the physical aspects of the pedal are operating properly- no binding at the pivot. Next, ensure fluid is fresh and clean and make sure both feed and return ports at rear brake master cylinder are clean and unobstructed. Next would be caliper- again, clean and unobstructed. I will bet that by the time you reach the third step in this process you will have solved your problem.
Rev Ryder said:Sure sounds like ABS pump to me.
