On my 2016, I ended up having to remove the jam nut and turning the little linkage all the way in until it locked in place. This dropped the level down to where I needed it.
I ran out of adjustment when I installed sport bike serrated metal pegs, lowered foot position by 3/4"/18.75MM, could not get the pedal to feel in a natural position. Found a rashed unit on Ebay for 10 bucks, cut it in twain and had a welder buddy affix the pedal to the underside, now it fits great.
