Ken Kawasaki recommends that the Final Gear Case Oil be changed every 12,000 Km (7500 mi) and the recommended oil type is; API-GL5 minimum or GL6 Hypoid Gear Oil SAE 80 / 90. It takes about 160 ml to refil. Honda markets the exact oil you need in a small squeeze bottle for easy refilling. Kevin
