RUFFSTUFF said:Have you tried full clockwise to full counter-clockwise or vice versa?
dog said:- mine was seized (2012 model). Replaced with a complete new shock unit under warranty. Its a known defect - some owners have had 2 or 3 units replaced on the trot.
- no amount of oiling will help a seized unit (one unit was soaked overnight in oil without any improvement).
- new units come with a rubber balloon over the adjuster.
jwolffie said:I got it working but it has 6 clicks of free play before the adjuster on the shock moves. Is the free play normal?
Thanks Fred, it is working now.Fred_Harmon_TX said:Get some good quality spray lubricant (NOT WD 40) and spray it under the head of the knob and it will free it up. Silicone spray lubricant, or Liquid Wrench Dry Slide works well for this.
As for clicks, my 2010 OEM shock gives me two clicks per revolution. I don't remember for sure, but I think my 08 shock did the same.
1882 said:Why is WD-40 a bad idea? Worked wonders for mine
Bartman said:How does the rear preload setup come from the factory? I have a 1month old 2012 and have not touched my rear setting. Is there a thread showing how far to unwind how far to crank back? A little in the dark on this issue? 180lbs average riding style.
Fred_Harmon_TX said:Most of the time the bike comes from the dealership with almost zero turns on the adjuster. I published an article in the summer Concourier about how to set up your suspension with a chart for various weight riders.
jwolffie said:Fred_Harmon_TX said:Most of the time the bike comes from the dealership with almost zero turns on the adjuster. I published an article in the summer Concourier about how to set up your suspension with a chart for various weight riders.
Summer of 2012? I don't see that issue in the online list. I am a paid member finally and all I can say is "wow, a lot of reading to catch up on. Thanks Fred for the help with my Gold Wing and now with the Concours. (I like the Concours better!)
nando said:Where can I find this "Summer Concourier" resource that I may read this article?
+1 :great:nando said:Fred, you da man bro! thanks so much. I am actually learning what is 'suspension'...'preciate it :great:
