A few weeks ago, someone had posted a article about cleaning and greasing the rear spline,now as Im ready to do the work, I dont remember who it was. I would like to find the article so I dont mess anything up. Thanks
As for removing and reinstalling the rear drive housing, so you can get to the splines I just follow the manual. Seems like the instructions were ok As for grease I used a molybdenum grease in a tube. Lightly coat the splines with a small auto parts brush. Back last summer when my rear drive started leaking, I took it to stealer to have it rebuilt, since it was leaking from the center and an inner seal and not the big outer one. I did not want to take it all apart myself. Anyways when I picked it up they gave me grease in a small dish and a brush for reassy. 2003 Concours, 56K COG #6953 IBA 28004 http://home.comcast.net/~slybones/Concours/connieMain.htm
