I'm thinking of replacing parts on the rear suspension. She has 89K on her with a zzr shock. I'm getting that "slipping on tar snakes feel" in the back. Would you recommend the bushings? - Anything else? Thanks
I would recomend anything that is loose... and the only way you will know what for sure is to get 'er up on the center stand and start looking. And by 'looking' I mean, try to move the real wheel and use your hands to feel where the movement is.
