After going through two Pilot GT rears in the last few years I went to BT45s last August and have racked up about 6000 miles on them. I got about 13k miles on the GTs but changed them out a little prematurely. The BTs have performed well but I have noticed some sort of slight side to side wobble in the bike at low speeds. When I had the bike up on the center stand over the weekend and in gear I noticed what I would consider a significant shift in the tire as it rotates. It appears to be side to side, a little less than a 1/4" of movement (looks like a bicycle wheel that's out of true). The rim appears to be rock solid with no similar movement, the tire looks to be evenly and completely seated on the rim, the suspension doesn't feel any different, and I can't feel any sideplay on the wheel itself. It was installed at a local shop but I don't think it was balanced. Did I get a bad tire or are there other issues I should look at? I think the movement has prematurely worn the tread as it appears there's probably not much more than 1 or 2k miles of tread left but they're coming off real soon as I don't trust it in this condition. I'm not a real aggresive rider but I don't doddle around either.
Thanks for any help or suggestions.
Marty
Marty
