Rembrant
Crotch Rocket
Hi Folks,
I have an '08 Concours-14 that I installed a Rostra CC kit on last winter/spring, and it has recently stopped working on me
I've put just over 20,000 miles on the bike since it was installed, and up until recently, the Rostra performed flawlessly. The first couple times that it quit, were when I hit fairly hard bumps...the cruise just stopped. Now, the past couple times, it just quits, at random, and then will not come on again. Now, it seems like after the bike sits, and cools down, it will allow me to engage the cruise, once...and then it quits, and won't let me engage it again.
I'm assuming that I baked the module? That it works, briefly after it cools down, then stops once it gets hot again? To be honest with you, with the amount of heat under all the front "Tupperware" of this bike, I'm surprised the darn thing worked at all...but still.
Any thoughts on checking/troubleshooting, or should I just look at replacing?
I'm pretty confident that my wiring is ok...I was very careful with all of it, and every connection is soldered...well, except for the few places where I had to use the bullet connectors, but any splicing into the Kawi wiring was soldered.
Any thoughts, experience, or ideas?
