Ken; Quite a bit of work. You have to remove the Bevel Drive Unit (BDU) To do that I suggest you need to get the shop manual from Kawasaki or Clymer, as it is quite involved. Remove LHS lowe plastic and Belly Pan Drain, Coolant& Oil. Remove Water Pump, Rear wheel, Rear Shock, and Rocker, & swinging arm. Disconnect oil pressure switch connection.remove clutch slave Then remove the BDU The selector spring is then exposed. Buy and fit new BDU gasket, and oil seals for gear selector, water pump etc. Takes about 2 hrs to get apart if you know what your doing 4 - 6 if you don't LoL Best to make sure it really is the spring, and its not that the linkage is binding.
thats exactly whats happened to me.. was stuck in 1st... and couldn't shift.... mow i'm waitin for the part to come in from japan.. Kawi Canada DOESN'T have the part in stock... hopefully in this week. have tried all dealerships in the area with no luck... its not a part anyone normally keeps i guess. some of the other online part source companies want 7-10 working days to ship.. Oh brother... just gonna have to wait it out.... will call down to buffalo on monday to see if any dealerships might have one.. david
