Hi y'all, I'm a long time COG member but haven't been active for a few years. I've been getting back into riding this year and the Connie started up just fine! Just needed a battery, air up the tires and shocks, and she was good to go. Oil was changed just before she was parked, tires were near new, fuel tank was full of good Amoco 93 with fuel stabilizer added. I started on another project bike a few days ago. I have a '87 ZL1000 Eliminator which had thrown a rod a few years ago. I had purchased a used Concours engine to put in it because the Eliminator engines are really hard to find. The main differences are the oil pan (no cooler on the Eli, but there is an oil temp switch), the air reed valves on top of the valve cover, gear ratios (both transmission internal ratios and final drive), and lack of the balancer shaft on the Eli. I'm in the process of swapping parts over (front bevel gears, oil pan) and preparing the replacement engine (adjusting valves, timing chain tensioner). I found that the gap was closed up on one of the spark plugs that I pulled out of the replacement engine. Anybody ever had a spark plug gap closed up on them? What was the prognosis? In my web searching I've found some examples that turned out to be broken ring lands. Just wondering if I should pull the head instead of putting the engine in the bike. Any way to see down in the cylinder without pulling the head? Thanks, Brian COG # 904
