I still have about 24 racks and then no more....I also have plenty os the MonoKEY mounting kits.
Do you have any pictures?I still have about 24 racks and then no more....I also have plenty os the MonoKEY mounting kits.
I don't remember Phil having any for a c10, but I've been wrong before..Do you have any pictures?
Yes. There is one available from SW-MOTECH for MonoLOCK trunks but they are hard to get and require a small modification to install.Do you sell just the Monokey mounting kit ?
I'd like to get a rack with the monokey setup. Still have one?I still have about 24 racks and then no more....I also have plenty os the MonoKEY mounting kits.
I just bought a 2012 so we are good to go. How can I purchase themYes, I have both. Your photo shows a C-10?? My racks are only for the C-1400.
I just sent an email to the one on your siteYes, I have both. Your photo shows a C-10?? My racks are only for the C-1400.
Please send me info for purchasing a monoKey mount please for a 22 C14Yes, I have both. Your photo shows a C-10?? My racks are only for the C-1400.
If you will give me an email address I will send a PayPal invoice. Thanks. PhilPlease send me info for purchasing a monoKey mount please for a 22 C14
So your rack goes on the metal stock plate, then my Givi plate on top of your rack. And then with the trunk off and the givi plate off I can stack a lot of gear on your rack. Am I picturing this correctly? Thank you!You have a MonoLOCK trunk. I can’t get those mounting kits but your plate can be attached to my rack for a stronger setup.
My bike stock had a composite rack (assume stock) attached to a metal plate (also assume stock). I took off the stock rack and installed the Givi to the metal plate that the stock rack was attached to. Does Phil's replace that metal underplate that the stock rack was attached to, which is what my Givi Monolock plate is currently attached to? I attached some pics in my earlier post.His rack replaces the flimsy stock rack.
I will take one Phil. Just the standard. I have MonoLOCK trunk but might want to get a MonoKEY trunk later. If I get the standard Phil rack, I can make that work with either GIVI with their universal adapter. Is that right?Four(4) left.
Sorry I didn’t properly answer your question. Yes, I have several MonoKEY kits.Do you sell just the Monokey mounting kit ?
