Welcome to COG Derk!! We're glad you're here! You might try an airhawk cushion. Some have commented that it raised them up. Maybe post a wanted ad in the classifieds and pick up a used one to experiment with. Make sure to put as little air in it as possible. Many make the mistake of over filling. HTH
6'4" also. I have a Baldwin seat, Murph's bar risers, AST peg lowering brackets. I used an Airhawk on my C-10 but not on the Baldwin. No perfect solution -- yet.
I have an airhawk and don't think that it will raise your seat height significantly. If you add more than a breath of air, you won't like the disconnected feeling. I personally believe that the most inexpensive way to get a little more height is to buy a used stock seat (should be able to pick one up for less than a $100). The airhawk when properly inflated like Bud mentioned, will increase your comfort level, though.
I'm not that tall, just long legged. My Russell Day Long is 1 1/2" taller than the stock seat, which is 2 1/2" - 3" total taller than your Sargent low. Sargent I believe is 1" - 1 1/2" lower than stock. That would make a big difference.
I imagine the best answer is a custom after market seat. One of the guys on here is selling his stock seat<---click. You could use it as is to gain a little height or send it in to get customized.
