So the D spec has a one ply sidewall, how would that be on the Connie as the rest of the tireD is the same, I will never ride two up so won’t be extra weight and I know I don’t have the cornering skills. As a lot of you here do, found a new set for about half the price of the A spec tires, sure am tempted to buy them!
