mellow yellow
Street Cruiser
I bought a pack of tire pressure indicators from walmart a couple of months ago. all you have to do is screw them onto the valve stems and check that the green indicators are visible. the indicators are pre calibrated for either 32 or 36 psi. I purchased the 36 psi's since my tire max. pressure is 42. The packaging says 'NOT TO USE ON MOTORCYCLES'. But so far I haven't had any problems. The only issue is that when you inflate your tires you need to check with a tire gauge. If you do decide to get them, it'll be at your own risk, as I've mention previously.
