Does removal of TMPS unti freeze up digital display?
What Steve said. Read up on replacing those with autel sensors if money is a concern.Does removal of TMPS unti freeze up digital display?
I don't see your location, but people here often will help out with programming. I just bought the programming pad and haven't even tried it out yet as don't need it till probably next tire change this season. You need the codes on the old ones to program the new ones. there are a couple of threads about this recently.Is programming simple and does one need to balance the tire/rim after installation?
Found the thread and the answer is apparently yes. Woop Woop!I've had my 2012 since January. Both TPMS were no good then. I thought I read somewhere that the batteries would finally drain completely and the front/rear battery warnings would stop. Is this true?
That would be great. Let um die and forget about um!
Why not replace them with the autel units? Quite a few including myself will tell you that TPMS saved their butt.Found the thread and the answer is apparently yes. Woop Woop!
Aye. This is my first bike with the sensors and they are kinda nice... when they work! I'll revisit the problem when I put tires on it. Thanks for the suggestion Bud.Why not replace them with the autel units? Quite a few including myself will tell you that TPMS saved their butt.
