Having a fully adjustable rear shock can be a great thing, but it can also be real easy to loose track of what adjustment you have where. So I decided to make a little graph in my left saddlebag with some velcro next to it so I can track where all my settings currently are, and I also made some charts showing my preload measurements for my own reference. I still need to make sag measurements with the bike fully packed for a trip, and make a third sag chart. I got my sag readings using the tool I posted about on here a couple weeks ago.
I have three little letters attached to velcro that I can move around on my scale. P represents how many turns I have my Preload adjuster set to, C represents where I have my Compression Damping adjuster set to, and R is for my Rebound Damping adjuster.
Next, I need to do the same thing for the front Traxxion fork settings.
Anyway, for those of you out there with an Ohlins or other fully adjustable rear shock, or front forks, you might want to consider doing something like this. While trying to dial in a suspension, it's really easy to loose track of settings, and this will help you keep your place and always know where everything is set at.
