Well after tens of thousands of miles, baking in the sun, freezing through Midwest winters, and being drug though countless storms, my ZUMO550 purchased in 2006 has lost a button. This was one of my first farkels and has spent time on multiple bikes through all sorts of conditions, so to be quite honest, I am surprised it lasted as long as it did :great: Here is what I have got, a hole where water will undoutedly enter the unit, and in the 100 or so miles from the failure point to home, I pushed the hole no less than a dozen times.
Another shot
My initial thoughts are to fill the hole with waterproof silicone and set the old button down into the goo and let it cure
http://www.amazon.com/Loctite-908570-2-7-Ounce-Silicone-Waterproof/dp/B0002BBX3U/ref=sr_1_1?ie=UTF8&qid=1423443483&sr=8-1&keywords=waterproof+silicone+sealant
The actual button only depresses about 1/16" so I would hope the silicone would be flexible enough that the button could keep working, while also keeping the water out of the GPS. This is similar to those who have siliconed the back of those fancy Aerostich voltmeter/clock/thermometers, so I think it might work. Any thoughts from the masses? Anyone else have a similar issue?
Another shot
