mellow yellow
Street Cruiser
hi, can someone tell me if changing over to steel brake lines will improve my braking or do I need to upgrade something else? thanks
Sport Rider said:Upgrade front end to ZRX1100 or 1200 and you get 6 piston calipers on each side. WOW! :great:
secarob said:Hazy, for now tightly wrap a bungee around your front brake lever and let it sit over night. You can sometimes get any residual air out of the system this way
Hazy said:Hmm... I'm not familiar with this trick. Do I need to take the resevoir cover off as well? I'll do this tonight!
Hazy said:What makes me nervous is the distance I have to pull before I actually get brake response. I have it set 1, which is the farthest out setting for the brake lever. It's just too much movement before something happens. It's a safety issue at this point.
