My dealer won't balance with rotors removed. I used to remove them thinking that they may ding them but nearly all of the wheels they balance have disk brakes and it is SOP to leave them on.
Ok, I was thinking they could get dinged when installing tire also. Definetly makes sense (more so now) that you want it balanced with rotors on. Thanks for responses.
