Sheesh. Was all set to get Michelin Pilot GTs for my C10. Then found out they're backordered, and they don't expect delivery until Aug 25th. Well, my original front tire is cupped and starting to howl in turns, and my original rear is almost down to no center groove. I don't think I want to wait until the end of the month. My backup plan was to get Dunlop Elite 3s - in the same sizes I ordered the Pilot GTs: 130/70H18 ft and 160/80H16 rr. THEN... the parts dude at the shop says "well, both the Pilot GTs you have on order, and the Elite 3's are bias ply, and your bike's original tires were radial [true enough], and I wouldn't recommened switching to bias ply". He also asked twice "Are you sure this size will fit? It's not the original size." So.... I thought I had done all the reading here I needed to... sounds like dozens if not hundreds of C10 riders have used the "wing" size tires with good results. But, are you using bias ply? I *think* a lot of the tires I read about were not available in radial. Not much selection for the 18 and 16 in rims. Help - can you tell me if I'm okay going with the bias-ply tires before I start another search looking for radials? I don't want to go with the original tire -they're crap, and I've heard the Dunlop D205's are not the greatest option. Thanks!! 2005 Concours - "CRT" until I a better name reveals itself.
