What is the best Ram mount base to use on a C-10? Thanks!
The Ram ball I have will not work. The threads on th mounting bolt are too small. How do I get a ball that has the correct size mounting bolt for those pre threaded holes?I have the x mount and love it . there are convenient threaded holes in the two master cylinders to mount the ram ball .
Thank you!!!RAM Mounts Ball Adapter with M10 X 1.25 Threaded Post RAM-B-349U with B Size 1" Ball https://www.amazon.com/dp/B0036G97D...abc_QVX7EXWMTWQ2H451SZQP?_encoding=UTF8&psc=1
I mounted a GPS off the tank once and immediately noticed it was unconformably outside my line of sight to safely reference when underway / naturally same result for phone as GPS. My .If you touch different areas of the bike while its running, there's a lot buzz at the Handlebars and other places, but virtually none at the fuel tank or fuel cap.
A good mount point would be from the gas cap bolts - also used for tank bag rings by some.
Guy, this is unfortunately true. I have an iPhone 12 Mini (love it), and I have a RAM mount mounted to the mirror post on my right handlebar. My bike needs some work, and is VERY buzzy - my iPhone started "buzzing" (vibrating) when I'd open the camera - the optical stabilization sensor was gone. Apple repaired it under warranty...... two days later it's doing it again. Will probably try tank/fairing mount in the spring.I assume you've seen this:
Cell Phones on bikes....
Careful, just don't shoot the messenger. I pay more attention to this stuff since I now have one.
