Hello!
I've been reading around, but it's hard to keep track of everything even with notes.
I bought a 2006 ZG1000 that I knew needed carb work as it only ran with choke open. Turns out the tank was rusty too.
Rebuilt carbs (float level between 17-18mm) got (most) rust out of the tank, played around with second fuel filter that made no difference in fueling. Changed spark plugs as old ones had symptoms of rich fuel (likely from riding with choke) and #1 had a tiny bit of oil.
After full carb rebuild with brand new parts and de-rusting tank it ran fine until I took it on the highway.
At 55mph and above it starts losing acceleration/jerking until it dies at 6th gear.
It won't restart unless I pull the choke and sit there killing the poor starter. Then I can ride home (below 55mph).
The problem goes away 80-90% if I open the fuel cap leading me to believe it's fuel starvation and maybe spark plug timing.
I changed all the fuel and vacuum lines - no dice.
Is there anything I can do to alleviate this that doesnt involve riding with gas cap open?
Secondary Incline fuel filter in/out made no difference.
Also:
-Have not done valves or carb timing yet
-Have not tested spark plug voltage (new ones seem to perform well but I still get LOUD back/after fire on decel and occasionally accel)
Edit: don't know if free power mod is done as there are black/yellow ground cables all over the place plugged into different parts of the frame/battery
Any and all help is appreciated. I'd love for this thing to be my daily commuter with gas approaching $7 in SoCal.
Thank you for reading and your time
-David
Edit: forgot to add I have California EVAP model
Also:
-David
