Yes, there is a ZRX front end swap (I have that) and then there is an upside down fork swap which involves a little more triple tree work than the ZRX, I think that was from a ZX7 / ZX9 donor. I am not sure if I heard of a ZZR swap, but my memory isn't what it used to be. What a difference, better brakes, better suspension, 17" tire. These parts/donor bikes are getting harder to find these days, my swap was around 9 years ago.
