electricbucky
Bicycle
Has anyone had to replace a mirror on a 2012 connie just wondering how easy or hard it is?
Thank you
Thank you
mnofpeace said:However, if you are looking to remove and or replace the bodywork piece, its a MUCH tougher job. This piece is connected to the frame from the underside of the segment from behind where the instrument panel is. To remove the screws connecting it, you will have to remove various segments of fairing, the windscreen, the instrument panel, and the respective inner segments of plastic that cover this side of the bike.
ProfessorKonk said:... unless you are replacing the broken subframe spar, something that can happen if the bike is allowed to roll over for a nap.
