Greetings Everyone,
I just joined COGs and hope to find some answers on an issue I am running into on my 2003 Kawasaki Concours with 55 000kms on the clock here in Edmonton, Alberta, Canada. The bike's starter performs great and never has an issue, however sometimes immediately after starting the lights will pulsate. You can see this in the dash when the Neutral light is on as well as the headlight. When I have this condition and hook up a multi-meter (aka voltmeter) to the battery, the voltage readings are in the range of 14.7 - 15.2V. At rest, the battery readings are just above 13V. Also to note, after riding for some time, it seems like the bike has a loss in power and when trying to maintain a constant speed the RPM's tend to fluctuate.
Is this a battery issue or an alternator / stator / rectifier issue or both? I have checked all wiring and fuses and connections. No issues were found. Is there another area I should be looking at? Possibly ignition? Any help in regards to this issue is greatly appreciated! Thank-you!
